[GRASSLIST:5907] Re: r.out.hdf
Hamish
hamish_nospam at yahoo.com
Thu Feb 24 21:00:47 EST 2005
> Is there a limitation on the windows binary grass v5.4 of r.out.hdf ?
> It doesn_t work on command line, nor tcltk.
It's not a standard GRASS module, and probably not built in the binary
distribution. Are there any "r.out.hdf" programs on the computer in a
Find-file search?
r.out.gdal should be able to export HDF4.
http://gdal.org/frmt_hdf4.html
otherwise you will have to compile yourself, maybe getting hdf5 support?
Hamish
