[GRASSLIST:5900] clean shp imported
ivan marchesini marchesini at unipg.it
Thu Feb 24 09:05:35 EST 2005
Dear users...
I've got a problem about an imported shp area file (land use map)...
it is composed of a large number of area that (I have seen using
v.digit) are all duplicated...
the problem is that I have tried to clean it:
v.clean input=clc2000 output=clc2000_clean tool=rmdupl,bpol
 thresh=0,0
or also:
but the map I obtain is still the same I was started from!!! there are
not differences....
do you know how can I solve the problem??? cna you help me????
thank you very much!!!!
ivan
Ivan Marchesini
Department of Civil and Environmental Engineering
University of Perugia
Via G. Duranti 93/a
06125
Perugia (Italy)
e-mail: marchesini at unipg.it
        ivan.marchesini at gmail.com
tel: +39(0)755853760
fax: +39(0)755853756
