[GRASSLIST:5915] 6.0.0beta2 configure failure
    Rich Shepard
    rshepard at appl-ecosys.com
    Sat Feb 26 13:10:06 EST 2005
   I seem stuck in an infinite loop here. Two problems configuring the build:
   1) For some reason, the script cannot locate the readline library (which
is installed). Is readline necessary for this version? If so, should I
specify /usr/lib as the path on the --with-readline line?
   2) The serious problem is that building GRASS with gdal support wants the
gdal path. But, building gdal with GRASS support wants the GRASS path.
Something's gotta' give. What are folks doing about this lock condition?
Thanks,
Rich
Dr. Richard B. Shepard, President
Applied Ecosystem Services, Inc. (TM)
<http://www.appl-ecosys.com>   Voice: 503-667-4517   Fax: 503-667-8863
