[GRASSLIST:5916] Re: 6.0.0beta2 configure failure
    Rich Shepard
    rshepard at appl-ecosys.com
    Sat Feb 26 14:27:00 EST 2005
On Sat, 26 Feb 2005, Rich Shepard wrote:
>  I seem stuck in an infinite loop here. Two problems configuring the build:
>  1) For some reason, the script cannot locate the readline library (which
> is installed). Is readline necessary for this version? If so, should I
> specify /usr/lib as the path on the --with-readline line?
   Found the answer to this in ./configure.
   However, despite installing fftw-3.0.1 the configure script will not find
the proper libraries. So I disabled this feature.
Rich
Dr. Richard B. Shepard, President
Applied Ecosystem Services, Inc. (TM)
<http://www.appl-ecosys.com>   Voice: 503-667-4517   Fax: 503-667-8863
