[GRASSLIST:5931] Re: Patchin big rasters in grass: how big can they be?
    Glynn Clements
    glynn at gclements.plus.com
    Mon Feb 28 06:11:33 EST 2005
Carlos Henrique Grohmann wrote:
> I'm trying to patch two big raster files (trying to produce a srtm map of
> Brazil), in a region of 48600 rows and 51600 cols. the mas are about 1.6Gb
> each. My grass was compiled with
> CFLAGS="-O3 -D_FILE_OFFSET_BITS=64 -mcpu=pentiumpro -Wall" LDFLAGS="-s"
> but r.patch gives me an error, like: can't write to collumn 31376...
> is there a limitation of the raster size?
Apart from file size issues, anything which counts the total number of
cells will have problems when a map has more than 2^31 (2147483648)
cells (as yours does: 48600 * 51600 = 2507760000).
Also, I can't see anything resembling that error message in the source
code for either r.patch or libgis.
