[GRASSLIST:5943] (GRASSLIST:5937) Re: loading VMAP0 data with v.in.ogr?
    Hamish
    hamish_nospam at yahoo.com
    Mon Feb 28 18:59:58 EST 2005
[cc GDAL list]
> > I'm trying to load some VMAP0 data (Digital Chart of the World) into
> > GRASS 6.0beta2 with v.in.ogr .. can't quite seem to get it to work.
> > VMAP0:
> >   http://www.mapability.com/info/vmap0_index.html
> > going back to ogrinfo, it finds the datasource but gives an "Illegal
> > instruction" error:
> > $ ogrinfo gltp:/vrf/var/local/TopoData/VMAP0/v0sas/vmaplv0/sasaus 'watrcrsl at hydro(*)_line'
> > Illegal instruction
> > I have batch renamed everything ending with a '.' in the v0sas/
> > tree, as per  http://article.gmane.org/gmane.comp.gis.freegis/315
> > but still the error. File system is local, system is Debian/testing
> > with self compiled OGDI driver and GDAL/OGR.
> Is it a recent OGDI driver? I tried a few months ago, successfully.
All newest official releases, AFAIK. ogdi-3.1.4, gdal 1.2.5 from source.
Debian/testing on intel P4.
> > $ ls /var/local/TopoData/VMAP0/v0sas/vmaplv0/sasaus/hydro/watrcrsl.*
> > /var/local/TopoData/VMAP0/v0sas/vmaplv0/sasaus/hydro/watrcrsl.lft
> > /var/local/TopoData/VMAP0/v0sas/vmaplv0/sasaus/hydro/watrcrsl.lfx
> AFAIK it dislikes the caps in the path (bad luck).
renamed to /var/local/topodata/vmap0/, same error.
> I was also cleaning the trailing dots, such as:
> mv ./view/viewsas/env. ./view/viewsas/env
> mv ./view/viewsas/themes. ./view/viewsas/themes
> mv ./vmaplv0/dht. ./vmaplv0/dht
> mv ./vmaplv0/lat. ./vmaplv0/lat
> mv ./vmaplv0/rference/cat. ./vmaplv0/rference/cat
> mv ./vmaplv0/rference/dbref/cnd. ./vmaplv0/rference/dbref/cnd
> mv ./vmaplv0/rference/dbref/csi. ./vmaplv0/rference/dbref/csi
> mv ./vmaplv0/rference/dbref/ebr. ./vmaplv0/rference/dbref/ebr
> mv ./vmaplv0/rference/dbref/edg. ./vmaplv0/rference/dbref/edg
> mv ./vmaplv0/rference/dbref/edx. ./vmaplv0/rference/dbref/edx
did that. All files have the execute flag set, I don't think that's the
trouble.
> Then it should work...
not yet...
$ grep -rI "Illegal instruction" *
in both GDAL and OGDI source dirs gives nothing..
Running it through the debugger shows this is as a SIGILL:
$ gdb `which ogrinfo`
GNU gdb 6.3-debian
This GDB was configured as "i386-linux"...Using host libthread_db library "/lib/libthread_db.so.1".
(gdb) run gltp:/vrf/var/local/topodata/vmap0/v0sas/vmaplv0/sasaus 'watrcrsl at hydro(*)_line'
Starting program: /usr/local/bin/ogrinfo gltp:/vrf/var/local/topodata/vmap0/v0sas/vmaplv0/sasaus 'watrcrsl at hydro(*)_line'
[Thread debugging using libthread_db enabled]
[New Thread 16384 (LWP 25147)]
Program received signal SIGILL, Illegal instruction.
[Switching to Thread 16384 (LWP 25147)]
0x40441aa7 in cln_ConvRegion (ClientID=0, gr=0x804b9bc, direction=1) at mathinline.h:494
494     __inline_mathcodeNP (floor, __x, \
(gdb) bt
#0  0x40441aa7 in cln_ConvRegion (ClientID=0, gr=0x804b9bc, direction=1) at mathinline.h:494
#1  0x4044076a in cln_GetGlobalBound (ClientID=0) at ../client.c:1490
#2  0x40440ff2 in cln_SetClientProjection (ClientID=0, projection=0x804d9e8 "+proj=longlat +datum=nad83")
    at ../client.c:2053
#3  0x4043f627 in cln_CreateClient (ReturnedID=0x804b7d4, URL=0x804b998 "") at ../client.c:432
#4  0x401efcb7 in OGROGDIDataSource::Open () from /usr/local/lib/libgdal.so.1
#5  0x401f022a in OGROGDIDriver::Open () from /usr/local/lib/libgdal.so.1
#6  0x401fc3f2 in OGRSFDriverRegistrar::Open () from /usr/local/lib/libgdal.so.1
#7  0x08049079 in main ()
(gdb) l
432               res = cln_SetClientProjection(*ReturnedID,projection);
433               free(projection);
434             } else {
435               res = &cln_dummy_result;
436               ecs_SetError(res,1,cln_messages[1]);
437               cln_FreeClient(&cln);
438               soc[*ReturnedID] = NULL;
439               *ReturnedID = -1;
440             }
441           }
(that source is in  ogdi-3.1.4/ogdi/c-api/client.c)
Hamish
