[GRASSLIST:5909] nviz running out of memory
Abhijit Menon-Sen
ams at wiw.org
Fri Feb 25 03:01:28 EST 2005
I want to use nviz to render a 3d surface from a PAN-sharpened Landsat
composite and an SRTM tile. When I tried this on a machine with 2GB of
physical memory, I got:
$ nviz el=srtm_138_45 col=ls2_138_45_rgb
Loading Data
Update elev null mask
gs_init_normbuff
Out of memory - Unable to load map
At the "gs_init_normbuff" stage, the RSS is 1GB (and the 2GB of swap I
added isn't being touched). The program dies shortly thereafter. Does
anyone else experience similar problems?
What are my options, short of buying more RAM?
-- ams
