[GRASSLIST:5273] grass installation and ogdi
Jesse Whittington
jesse.whittington at lycos.com
Sun Jan 9 12:43:23 EST 2005
I would like to switch from ArcInfo to GRASS for the analysis of wildlife data, but am having difficulty installing it on Linux Mandrake 10.1.
When I try to install grass 5.7, 5.4, or 5.0 I receive a message similar to the following:
Sorry, the following package(s) can't be selected:
gdal-python-1.2.2-2thac.i586 (due to unsatisfied libgdal1[==1.2.2]) libgdal1-1.2.2-1mdk.i586 (due to unsatisfied libogdi31.so)
When I found the package ogdi and tried to install it I continually receive the message:
Some package requested cannot be installed:
ogdi-3.1.2-1mdk.src.rpm (due to unsatisfied zlib-devel) OR (unsatisfied libzlib for ogdi-3.1.2-1mdk.i586.rpm)
Thus, installation of GRASS appears to depend on the zlib, which seems to install just fine although I'm not sure how to test that.
I've tried a couple versions of the grass, odgi, and zlib's without success. Here's the list of packages I have.
expat-1.95.8-1mdk.i586.rpm
expat-1.95.8-1mdk.ppc.rpm
expat-1.95.8-1mdk.src.rpm
gdal-1.2.5-2mdk.src.rpm
gdal-python-1.2.2-2thac.i586.rpm
grass-5.0.3-3mdk.i586.rpm
grass54-5.4.0-1mdk.src.rpm
grass57-5.7.0-3mdk.src.rpm
libfftw2-2.1.5-3mdk.i586.rpm
libfftw2-devel-2.1.5-3thac.i586.rpm
libgdal1-1.2.2-1mdk.i586.rpm
libpq3-7.4.5-4mdk.i586.rpm
libproj0-4.4.8-1mdk.i586.rpm
proj-4.4.8-1mdk.src.rpm
xterm-196-1mdk.i586.rpm
zlib-1.2.1.1-3mdk.src.rpm
zlib-1.2.2.1-1mdk.src.rpm
I'm installing these by using the root console and typing:
> urpmi ogdi-3.1.2-1mdk.i586.rpm
I would be grateful for any help on how to fix this problem. I'm new to Linux and am open to using a different operating system.
Jesse Whittington
Find what you are looking for with the Lycos Yellow Pages
http://r.lycos.com/r/yp_emailfooter/http://yellowpages.lycos.com/default.asp?SRC=lycos10
