[GRASSLIST:5275] problems with v.out.ogr
Marta Benito
marta.benito at uam.es
Mon Jan 10 11:04:42 EST 2005
I am having problems with the v.out.ogr command (and with PROJ in
general):
v.out.ogr input=mapa dsn=./ layer=layer
v.out.ogr: relocation error:
/usr/local/grass-5.7.cvs/lib/libgrass_gproj.so: undefined symbol:
pj_get_def
I have tried to add the library path to /etc/ld.so.conf and run
/sbin/ldconf but it does not work.
Also I have tried to rebuild proj.4 but the problem remains.
Another programs of proj neither seems to work properly:
nad2nad
nad2nad: Symbol `pj_release' has different size in shared object,
consider re-linking
Rel. 4.4.9, 29 Oct 2004
Thank you in advance
Marta
