[GRASSLIST:5276] Re: NO MORE problems with v.out.ogr
Marta Benito
marta.benito at uam.es
Mon Jan 10 11:42:51 EST 2005
Sorry...
the problem is resolved, there were old libraries. I have just clean it
and reinstall proj 4 and everything works....
Marta
El lun, 10-01-2005 a las 17:04, Marta Benito escribió:
> Hi,
> I am having problems with the v.out.ogr command (and with PROJ in
> general):
> v.out.ogr input=mapa dsn=./ layer=layer
> v.out.ogr: relocation error:
> /usr/local/grass-5.7.cvs/lib/libgrass_gproj.so: undefined symbol:
> pj_get_def
> I have tried to add the library path to /etc/ld.so.conf and run
> /sbin/ldconf but it does not work.
> Also I have tried to rebuild proj.4 but the problem remains.
> Another programs of proj neither seems to work properly:
> nad2nad
> nad2nad: Symbol `pj_release' has different size in shared object,
> consider re-linking
> Rel. 4.4.9, 29 Oct 2004
> Thank you in advance
> Marta
