[GRASSLIST:5293] Re: segmentation fault with v.overlay
Dylan Beaudette
dylan at iici.no-ip.org
Tue Jan 11 12:39:25 EST 2005
On Tuesday 11 January 2005 09:18 am, Marta Benito wrote:
> I have update GRASS, and the problem is still appearing, without writing
> anything :
> v.overlay ainput=mapa1 binput=mapa2 output=output operator=and
> Segmentation fault
> thank you
I wonder if this is in any way related to the Segfaults that v.out.ascii is
causing...
Attached is the output from strace v.out.ascii
Dylan
> El mar, 11-01-2005 a las 17:39, Radim Blazek escribió:
> > First try to update GRASS, your version is almost 2 months old.
> > Radim
> > Marta Benito wrote:
> > > Hi, I am trying to overlay to vectorial (area) maps, mapa1 and mapa2
> > > but without success:
> > > # v.db.connect -p mapa1
> > > Vector map <mapa1> is connected by:
> > > field <1> table <mapa1> in database
> > > </home/marta/grassdata/espanya_modelo_devel/pred_ppinea/dbf/> through
> > > driver <dbf> with
> > > key <cat>
> > > # v.db.connect -p mapa2
> > > Vector map <mapa2> is connected by:
> > > field <1> table <mapa2> in database
> > > driver <dbf> with
> > > key <cat>
> > > BUT:
> > > # v.overlay ainput=mapa1 binput=mapa2 output=output operator=and
> > >------ Writing attributes ...
> > > Copying ainput lines ... 100%
> > >------ Copying binput lines ... 100%
> > >------ Buiding partial topology ...
> > >------ Breaking lines ...
> > > Intersections: 6427
> > >------ Removing duplicates ...
> > > Duplicates: 30
> > >------ Cleaning boundaries at nodes ...
> > > Modifications: 0
> > >------ Attaching islands ...
> > > Building topology ...
> > > Building areas: 100%
> > > 1869 areas built
> > > 986 isles built
> > > Attaching islands: 100%
> > > Topology was built.
> > > Number of nodes : 8771
> > > Number of primitives: 11422
> > > Number of points : 0
> > > Number of lines : 0
> > > Number of boundaries: 11422
> > > Number of centroids : 0
> > > Number of areas : 1869
> > > Number of isles : 986
> > > Number of areas without centroid : 1869
> > >------ Querying input 'mapa1 at pred_ppinea' ... Segmentation fault.
> > > Any ideas?
> > > Many thanks
Dylan Beaudette
Soils and Biogeochemistry Graduate Group
University of California at Davis
530.754.7341
Type: text/x-log
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20050111/7bf2a553/strace.bin
