[GRASSLIST:5360] Re: [bug #2906] (grass) v.extract, v.overlay
and database
Radim Blazek
blazek at itc.it
Fri Jan 14 06:13:52 EST 2005
For me it works.
Radim
lourdes villaescusa hernandez wrote:
> --------------------------- Missatge original ----------------------------
> Assumpte: Re: [bug #2906] (grass) v.extract, v.overlay and database De:
> "lourdes villaescusa hernandez" <lvillaescusa at alumnes.udl.es> Data:
> Thu, Gener 13, 2005 13:13
> A: "Radim Blazek via RT" <grass-bugs at intevation.de>
> I put -1 for NEW, but I don't obtain the dbf table... when I do a query
> with mouse, for instance, in this new vector map I obtain this:
> 368180.14731586(E) 4611931.60424469(N)
> explocastell4 in explocastell Centroid
> field: 1
> category: 1126
> Database connection not defined
> The category 1126 is from the original dbf table, but I need a table with
> all the fields of the original table it is not posible? may I do a
> connection? I have tried but without success...
> Thank you very much,
> Lourdes
>>Request Tracker wrote:
>>>this bug's URL: http://intevation.de/rt/webrt?serial_num=2906
>>>Subject: v.extract, v.overlay and database connection
>>>I have a vector map with a database connected, but when I do a query by
> atributes (v.extract) I loose this connection, I obtain a vectorial
> without
>>>database,
>>The 'new' option is < 0? The table is created only for new=-1.
>> > and I want a new data base (smaller) for this new vectorial map,
>>>it is possible? I have tried to do v.db.connect after, I have tried
> also to
>>>do the connection in the internal files but without success...
>>>With v.overlay I obtain a new data base (dbf) for the new map, but this
> dbf
>>>file do not have all the data (fields) of the original dbf... how can I
> obtain the same dbf table but only for the new vector map?
>>You have probably old version of GRASS 5.7, try something > Fri Dec 3
> 16:27:34 2004.
>>Radim
>>--- Headers Follow ---
>>>From blazek at itc.it Thu Jan 13 12:26:43 2005
>>Return-Path: <blazek at itc.it>
>>Delivered-To: grass-bugs at lists.intevation.de
>>Received: from mail.intevation.de (aktaia [212.95.126.10])
>> by lists.intevation.de (Postfix) with ESMTP id DCCA1102C10
>> for <grass-bugs at lists.intevation.de>; Thu, 13 Jan 2005 12:26:43 +0100
>>(CET)
>>Received: from localhost (localhost [127.0.0.1])
>> by mail.intevation.de (Postfix) with ESMTP id 9353837123
>>(CET)
>>Received: from mail.itc.it (ns.itc.it [217.77.80.3])
>> by mail.intevation.de (Postfix) with ESMTP id 0193536DEF
>> for <grass-bugs at intevation.de>; Thu, 13 Jan 2005 12:26:41 +0100 (CET)
>>Received: from ntmain.itc.it ([10.0.20.40])
>> by mail.itc.it (8.12.11/8.12.11) with SMTP id j0DBQfaB007382
>>Received: from orchestra.itc.it ([10.0.10.11])
>> by ntmain.itc.it (SMSSMTP 4.0.4.64) with SMTP id M2005011312264128940
>>Received: from itc.it (janacek [10.40.0.140])
>> by orchestra.itc.it (8.12.11/8.12.11) with ESMTP id j0DBQfYX029169;
>>Message-ID: <41E65AEA.1010600 at itc.it>
>>Date: Thu, 13 Jan 2005 12:26:34 +0100
>>From: Radim Blazek <blazek at itc.it>
>>User-Agent: Mozilla/5.0 (X11; U; Linux i686; en-US; rv:1.6)
> Gecko/20040113 X-Accept-Language: en-us, en
>>MIME-Version: 1.0
>>To: Request Tracker <grass-bugs at intevation.de>
>>Cc: grass5 at grass.itc.it
>>Subject: Re: [GRASS5] [bug #2906] (grass) v.extract, v.overlay and database
>> connection
>>References: <20050113110104.9A54A102BDC at lists.intevation.de>
>>In-Reply-To: <20050113110104.9A54A102BDC at lists.intevation.de>
>>Content-Type: text/plain; charset=us-ascii; format=flowed
>>Content-Transfer-Encoding: 7bit
>>X-Spam-Status: No, hits=-4.9 tagged_above=-999.0 required=3.0
>>tests=BAYES_00
>>X-Spam-Level:
>>-------------------------------------------- Managed by Request Tracker
