[GRASSLIST:5358] Re: [bug #2906] (grass) v.extract, v.overlay and database
    lourdes villaescusa hernandez
    lvillaescusa at alumnes.udl.es
    Fri Jan 14 05:26:07 EST 2005
--------------------------- Missatge original ----------------------------
Assumpte: Re: [bug #2906] (grass) v.extract, v.overlay and database De:
   "lourdes villaescusa hernandez" <lvillaescusa at alumnes.udl.es> Data:
Thu, Gener 13, 2005 13:13
A:        "Radim Blazek via RT" <grass-bugs at intevation.de>
I put -1 for NEW, but I don't obtain the dbf table... when I do a query
with mouse, for instance, in this new vector map I obtain this:
368180.14731586(E) 4611931.60424469(N)
explocastell4 in explocastell  Centroid
field: 1
category: 1126
Database connection not defined
The category 1126 is from the original dbf table, but I need a table with
all the fields of the original table it is not posible? may I do a
connection? I have tried but without success...
Thank you very much,
Lourdes
> Request Tracker wrote:
>> this bug's URL: http://intevation.de/rt/webrt?serial_num=2906
>> Subject: v.extract, v.overlay and database connection
>> I have a vector map with a database connected, but when I do a query by
atributes (v.extract) I loose this connection, I obtain a vectorial
without
>> database,
> The 'new' option is < 0? The table is created only for new=-1.
>  > and I want a new data base (smaller) for this new vectorial map,
>> it is possible? I have tried to do v.db.connect after, I have tried
also to
>> do the connection in the internal files but without success...
>> With v.overlay I obtain a new data base (dbf) for the new map, but this
dbf
>> file do not have all the data (fields) of the original dbf... how can I
obtain the same dbf table but only for the new vector map?
> You have probably old version of GRASS 5.7, try something > Fri Dec 3
16:27:34 2004.
> Radim
> --- Headers Follow ---
>>From blazek at itc.it  Thu Jan 13 12:26:43 2005
> Return-Path: <blazek at itc.it>
> Delivered-To: grass-bugs at lists.intevation.de
> Received: from mail.intevation.de (aktaia [212.95.126.10])
> 	by lists.intevation.de (Postfix) with ESMTP id DCCA1102C10
> 	for <grass-bugs at lists.intevation.de>; Thu, 13 Jan 2005 12:26:43 +0100
> (CET)
> Received: from localhost (localhost [127.0.0.1])
> 	by mail.intevation.de (Postfix) with ESMTP id 9353837123
> (CET)
> Received: from mail.itc.it (ns.itc.it [217.77.80.3])
> 	by mail.intevation.de (Postfix) with ESMTP id 0193536DEF
> 	for <grass-bugs at intevation.de>; Thu, 13 Jan 2005 12:26:41 +0100 (CET)
> Received: from ntmain.itc.it ([10.0.20.40])
> 	by mail.itc.it (8.12.11/8.12.11) with SMTP id j0DBQfaB007382
> Received: from orchestra.itc.it ([10.0.10.11])
>  by ntmain.itc.it (SMSSMTP 4.0.4.64) with SMTP id M2005011312264128940
> Received: from itc.it (janacek [10.40.0.140])
> 	by orchestra.itc.it (8.12.11/8.12.11) with ESMTP id j0DBQfYX029169;
> Message-ID: <41E65AEA.1010600 at itc.it>
> Date: Thu, 13 Jan 2005 12:26:34 +0100
> From: Radim Blazek <blazek at itc.it>
> User-Agent: Mozilla/5.0 (X11; U; Linux i686; en-US; rv:1.6)
Gecko/20040113 X-Accept-Language: en-us, en
> MIME-Version: 1.0
> To: Request Tracker <grass-bugs at intevation.de>
> Cc: grass5 at grass.itc.it
> Subject: Re: [GRASS5] [bug #2906] (grass) v.extract, v.overlay and database
>  connection
> References: <20050113110104.9A54A102BDC at lists.intevation.de>
> In-Reply-To: <20050113110104.9A54A102BDC at lists.intevation.de>
> Content-Type: text/plain; charset=us-ascii; format=flowed
> Content-Transfer-Encoding: 7bit
> X-Spam-Status: No, hits=-4.9 tagged_above=-999.0 required=3.0
> tests=BAYES_00
> X-Spam-Level:
> -------------------------------------------- Managed by Request Tracker
