[GRASSLIST:5386] Re: v.in.e00 errors
Markus Neteler neteler at itc.it
Mon Jan 17 06:09:23 EST 2005
On Mon, Jan 17, 2005 at 11:58:17AM +0100, Moritz Lennert wrote:
> Michael,
> On Mon, January 17, 2005 10:57, Markus Neteler said:
> > On Sat, Jan 15, 2005 at 10:04:28AM -0700, Michael Barton wrote:
> >> Again I got some strange errors that I initially blamed on a directory
> >> structure that had a directory name with a space in it (from when I was a
> >> carefree Mac person that didn't think about unix naming conventions). Fixed
> >> that. Now I still get an error, but this is something that can be worked
> >> with. Here it is and below I'll recount what is happening. It is probably
> >> pretty easy to fix.
> > At least it's easy to debug :-)
> > Open the v.in.e00 file, add ' -x' to the first #/bin/sh line and run again.
> > It will then report every line. If you don't see anything wrong,
> > please send the output to me for inspection.
> > So, for debugging, use:
> > #!/bin/sh -x
> I'm not sure about this, but if I understand the script correctly E00NAME is
> only the basename without extension, but doesn't v.in.ogr's "dsn" need the
> extension ?
No. v.in.ogr takes the output of avcimport which is a directory with
identical name to the e00 file(s).
Markus
