[GRASSLIST:5385] Re: v.in.e00 errors
Moritz Lennert
mlennert at club.worldonline.be
Mon Jan 17 05:58:17 EST 2005
Michael,
On Mon, January 17, 2005 10:57, Markus Neteler said:
> On Sat, Jan 15, 2005 at 10:04:28AM -0700, Michael Barton wrote:
>> Again I got some strange errors that I initially blamed on a directory
>> structure that had a directory name with a space in it (from when I was a
>> carefree Mac person that didn't think about unix naming conventions). Fixed
>> that. Now I still get an error, but this is something that can be worked
>> with. Here it is and below I'll recount what is happening. It is probably
>> pretty easy to fix.
> At least it's easy to debug :-)
> Open the v.in.e00 file, add ' -x' to the first #/bin/sh line and run again.
> It will then report every line. If you don't see anything wrong,
> please send the output to me for inspection.
> So, for debugging, use:
> #!/bin/sh -x
I'm not sure about this, but if I understand the script correctly E00NAME is
only the basename without extension, but doesn't v.in.ogr's "dsn" need the
extension ?
Moritz
