[GRASSLIST:5409] Re: problems with grass 6.0 beta
Andy Bernat
abernatj at cox.net
Mon Jan 17 19:40:51 EST 2005
Roger,
Thanks for the excellent advice. After editting ld.so.conf and running
ldconfig everything worked fine
Best regards,
Andy Bernat
Roger Bivand wrote:
>On Sat, 15 Jan 2005, Andy Bernat wrote:
>>Greetings,
>>I just downloaded and compiled grass-6.0.0beta1. At first I got
>>configure errors because gdal libraries couldn't be found. After I
>>installed gdal 1.2.5 (without grass support because no matter what
>>directories I specified, it couldn't find the grass libraries), there
>>were no errors after configure and make. When I started grass60, it
>>loaded the initial tcl menu where I chose my mapset but then I got the
>>following error:
>>Error in startup script: ps.map: error while loading shared libraries:
>>libgdal.so.1: cannot open shared object file: No such file or directory
>> while executing
>>"exec ps.map -p"
>> (procedure "DmPrint::init" line 14)
>> invoked from within
>>"DmPrint::init"
>> (procedure "main" line 31)
>> invoked from within
>>"main $argc $argv"
>> (file "/usr/local/grass-6.0.0beta1/etc/dm/d.m.tcl" line 890)
>>The puzzling thing is the shared library libgdal.so.1 seems to be alive
>>and well. Can anyone tell me how to fix this? I looked in the files
>>indicated but I don't know enough to know what really went wrong.
>>Thanks in advance for any advice.
>This is a Linux system, isn't it?
>Does "alive and well" mean that it is in /usr/local/lib, or that it is in
>/usr/local/lib (or wherever) and that directory is in /etc/ld.so.conf and
>you've run ldconfig since installing gdal (sorry if this is obvious, but
>it's a hole lots of us fall into, even if we do know better)? Editing
>/etc/ld.so.conf and running ldconfig are for root. Does running gdalinfo
>from the shell prompt work:
>$ gdalinfo --version
>GDAL 1.2.5.0, released 2004/11/22
>for example?
>Good luck,
>Roger
>>-Andy.
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20050117/b8379032/attachment.html
