[GRASSLIST:5471] Re: geogrid in ps.map
Michael Barton
michael.barton at asu.edu
Fri Jan 21 11:34:33 EST 2005
Ian,
This is way out of date, given that 5.7 (now 6.0.0 beta 1) is the rapid
development version. MANY changes and fixes have been implemented since last
May.
Given that you are using a Mac, I highly recommend you get Lorenzo Moretti's
binaries and install them. Install the new libraries and GRASS 6.0.0 beta1.
Make sure that you delete any old copies of gdal and proj4 libraries and
utilities you may have in /usr/local/bin and /usr/local/lib. These can
confuse Moretti's binaries that use very new versions of both utilities and
keeps them in /usr/local/grasslib/bin and /usr/local/grasslib/lib. Also make
sure that /usr/local/grasslib/bin is in your path to make life easier.
Hope this solves your issues.
Michael
On 1/20/05 12:44 PM, "Ian MacMillan" <ian_macmillan at umail.ucsb.edu> wrote:
> Hi all, I am using grass5.7 on osx (May 2004 or so) and I am trying to
> make a world mercator map using ps.map. I would like to add a geogrid,
> however the output only gives latitudinal lines, no longitudes. No
> errors were returned. The command I gave was
> ps.map input=- output=test.eps -e
> geogrid 30 d
> color black
> numbers 1
> end
> end
> g.region -p yields
> projection: 99 (Mercator)
> zone: 0
> datum: ** unknown (default: WGS84) **
> ellipsoid: wgs84
> north: 11714654.84
> south: -11714654.84
> west: -20037508.34
> east: 20037508.34
> nsres: 3697.80771465
> ewres: 3710.64969259
> rows: 6336
> cols: 10800
> Alternatively, I have also tried to import (using v.proj) a worldwide
> vector grid with 30 degree spacing, however every attempt to import
> yields in errors such as (using grass 5.3):
> Input Projection Parameters: +proj=latlong +a=6378137
> +es=0.006694379990141316 +towgs84=0.000,0.000,0.000
> Output Projection Parameters: +proj=merc +lat_ts=0.0000000000
> +lon_0=180.0000000000 +k_0=1.0000000000 +a=6378137
> Creating dig file...
> pj_transform() failed
> cause: latitude or longitude exceeded limits
> Error in pj_do_proj
> OR (using 5.7)
> v.proj input=grid30 location=latlong_wgs84
> Input Projection Parameters: +proj=latlong +a=6378137 +rf=298.257223563
> +no_defs +towgs84=0.000,0.000,0.000
> Input Unit Factor: 1
> +lon_0=180.0000000000 +k_0=1.0000000000 +a=6378137 +rf=298.257223563
> +no_defs
> Output Unit Factor: 1
> Creating vector file...
> Building topology ...
> Registering lines:
> At this point v.proj stops running. Trying to display the vector with
> yields:
> GRASS 5.7.0:~ > d.vect grid30
> WARNING: coor files of vector 'grid30 at ianmacmillan' is larger than it
> should be (14312 bytes excess).
> WARNING: Cannot display areas, topology not available
> I think there is a problem with worldwide mercator projections, but I
> can't figure what it is. Displaying other worldwide data (I can't
> remember how I got it into this location in the first place) shows that
> the region is appropriate for a world map. It is hard to tell for sure
> though since units are measured in meters.
> Any ideas?
> Thanks,
> Ian
______________________________
Michael Barton, Professor of Anthropology
School of Human Evolution and Social Change
Arizona State University
Tempe, AZ 85287-2402
USA
voice: 480-965-6262; fax: 480-965-7671
www: http://www.public.asu.edu/~cmbarton
