[GRASSLIST:5459] geogrid in ps.map
Ian MacMillan
ian_macmillan at umail.ucsb.edu
Thu Jan 20 14:44:32 EST 2005
Hi all, I am using grass5.7 on osx (May 2004 or so) and I am trying to
make a world mercator map using ps.map. I would like to add a geogrid,
however the output only gives latitudinal lines, no longitudes. No
errors were returned. The command I gave was
ps.map input=- output=test.eps -e
geogrid 30 d
color black
numbers 1
end
end
g.region -p yields
projection: 99 (Mercator)
zone: 0
datum: ** unknown (default: WGS84) **
ellipsoid: wgs84
north: 11714654.84
south: -11714654.84
west: -20037508.34
east: 20037508.34
nsres: 3697.80771465
ewres: 3710.64969259
rows: 6336
cols: 10800
Alternatively, I have also tried to import (using v.proj) a worldwide
vector grid with 30 degree spacing, however every attempt to import
yields in errors such as (using grass 5.3):
Input Projection Parameters: +proj=latlong +a=6378137
+es=0.006694379990141316 +towgs84=0.000,0.000,0.000
Output Projection Parameters: +proj=merc +lat_ts=0.0000000000
+lon_0=180.0000000000 +k_0=1.0000000000 +a=6378137
Creating dig file...
pj_transform() failed
cause: latitude or longitude exceeded limits
Error in pj_do_proj
OR (using 5.7)
v.proj input=grid30 location=latlong_wgs84
Input Projection Parameters: +proj=latlong +a=6378137 +rf=298.257223563
+no_defs +towgs84=0.000,0.000,0.000
Input Unit Factor: 1
+lon_0=180.0000000000 +k_0=1.0000000000 +a=6378137 +rf=298.257223563
+no_defs
Output Unit Factor: 1
Creating vector file...
Building topology ...
Registering lines:
At this point v.proj stops running. Trying to display the vector with
yields:
GRASS 5.7.0:~ > d.vect grid30
WARNING: coor files of vector 'grid30 at ianmacmillan' is larger than it
should be (14312 bytes excess).
WARNING: Cannot display areas, topology not available
I think there is a problem with worldwide mercator projections, but I
can't figure what it is. Displaying other worldwide data (I can't
remember how I got it into this location in the first place) shows that
the region is appropriate for a world map. It is hard to tell for sure
though since units are measured in meters.
Any ideas?
Thanks,
Ian
