[GRASSLIST:5462] Re: GRASS and MODFLOW
Thomas Adams Thomas.Adams at noaa.gov
Thu Jan 20 19:14:30 EST 2005
Jaime,
This sounds pretty exciting to me. I look forward to seeing your
documentation!
Regards,
Tom
Jaime Carrera wrote:
>>>We have created a new module that links GRASS with
>>>MODFLOW. The module uses raster and site data to
>>>create MODFLOW's files and then imports the
>>simulated
>>>heads and drawdowns as raster maps.
>>>I am currenly writing a small tutorial on how to
>>use
>>>this module, and should be finished by friday. So
>>far
>>>I've uploaded the html man page on GRASS' TWIKI
>>and
>>>any comments are welcome:
>http://grass.gdf-hannover.de/twiki/bin/view/GRASS/JaimeCarrera
>>Note r.out.ascii can create MODFLOW arrays too.
>>Glad to see some more model integration.
>>Hamish
>Dear Hamish,
>Yes, it is true that r.out.ascii can export a raster
>map as an ASCII file which can be used to create
>MODFLOW's input files as it does not create a
>ready-to- use array. In my opinion this can only be
>done by someone who knows the nuts and bolts of
>MODFLOW, as setting up the files to run MODFLOW is not
>an easy task (e.g. the user needs to know where to
>place each exported array in the specific files read
>by MODFLOW as well as the header/footer that goes
>before/after each array). In summary, each file used
>by MODFLOW is comprised of different arrays which have
>to be in a specific order.
>The idea behind this module is to use GRASS as a
>preprocessor and post-processor for MODFLOW, as it not
>only creates the required input files but also
>executes MODFLOW (providing it is installed in the
>system). The module can be used to perform both
>steady-state and transient simulations for multilayer
>aquifers.
>Jaime
>_________________________________________________________
>Do You Yahoo!?
>Información de Estados Unidos y América Latina, en Yahoo! Noticias.
>Visítanos en http://noticias.espanol.yahoo.com
Thomas E Adams
National Weather Service
Ohio River Forecast Center
1901 South State Route 134
Wilmington, OH 45177
EMAIL:	thomas.adams at noaa.gov
VOICE:	937-383-0528
FAX:	937-383-0033
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20050120/eeab0e4d/attachment.html
