[GRASSLIST:5476] Re: vectors in NVIZ [solved]
Dylan Beaudette dylan at iici.no-ip.org
Fri Jan 21 14:39:28 EST 2005
Michael-
Thanks for the pointers. In error, i was trying to make NVIZ display vector
areas... something that I thought that it could do...
This clears up a lot of "problems" that I had been having with NVIZ over the
last couple of months...
Perhaps it would be a good idea to mention this somwhere in the NVIZ
interface..? an error message issued when vector areas are loaded?
Dylan
On Friday 21 January 2005 08:30 am, Michael Barton wrote:
> Dylan,
> I just checked my GRASS 6.0.0 beta1 version. NVIZ displays vectors just
> fine. I could view them as flat or following the surface and the z factor
> raised or lowered them above the surface correctly. There are a couple of
> caveats, especially if you are using a slightly older version.
> 1. NVIZ does not display vector areas. They used to crash NVIZ, but now
> they just don't display. If you want to display areas you either need to
> -transform them to boundaries (i.e., lines) and display the outlines of the
> areas, or
>     -transform them to raster coverages and use the coverage as the color
> drape over your surface.
> 2. Vector lines display under the "vector" panel of old NVIZ. In the new
> NVIZ, this panel is called "vector lines" to make this clear. Vector points
> display under the "sites" panel of old NVIZ. Again, in the current version,
> this is called the "vector points" panel to make the clear.
> Michael
> On 1/20/05 3:50 PM, "Dylan Beaudette" <dylan at iici.no-ip.org> wrote:
> > Hi everyone,
> > In the last couple of GRASS 5.7-CVS  versions (as of a couple of weeks
> > ago) vectors are not being displayed in NVIZ... they either show up flat
> > at z=0, or not at all... I have checked to make sure that the appropriate
> > settings are correct, and am not sure what is going on...
> > Any ideas?
> ______________________________
> Michael Barton, Professor of Anthropology
> School of Human Evolution and Social Change
> Arizona State University
> Tempe, AZ  85287-2402
> USA
> voice: 480-965-6262; fax: 480-965-7671
> www: http://www.public.asu.edu/~cmbarton
