[GRASSLIST:5482] Re: file g.gisenv / clean_temp / run not found after compilation
Markus Neteler
neteler at itc.it
Sat Jan 22 04:18:53 EST 2005
On Fri, Jan 21, 2005 at 11:02:52PM +0530, Force3 Team wrote:
> -----BEGIN PGP SIGNED MESSAGE-----
> Hash: SHA1
> Hi,
> I am using Grass 5.4.0 for Arm Linux Handheld.
> I compiles the Grass And Baby Grass for arm-linux and loaded to handheld.
> but when i run the grass54, it ask for file g.gisenv
> in the grass54 bin folder.
> unfortunatly the files is not found after compiling ?
> for the native machine it work fine.
> So,
> 1. Can any one tell me, how can i compile only these file for
> arm-linux-gcc ?
> 2. The File grass54/etc/clean_temp
> 3. The File grass54/etc/run
> are also not present.
It may be possible (can't remember and away from the office
machine now) that the desired modules have to be included
into the babyGRASS source code.
Just add the relevant directories to
handheld/babyGRASS_packagingsrc.sh
package and compile again.
Good luck
Markus
