[GRASSLIST:5501] Re: grass60 in command line?
Moritz Lennert mlennert at club.worldonline.be
Mon Jan 24 10:24:09 EST 2005
On Fri, January 21, 2005 21:31, Kirk R. Wythers said:
>> i tried to use the command line but always a box appears to be
>> clicked....
> What commands are you trying to run. most grass modules can run either
> with a GUI or from the command line (a few such as v.digit and a few of
> the image modules) require a gui). Let the list know what modules you
> are trying to run and I (or someone with more experience than I) will
> try and help.
If you type just the name of the command without any flags or options you will
get the GUI "box". If you type the command with options, you will not the GUI.
Moritz
