[GRASSLIST:5506] Re: help!!! remove isles
Hamish
hamish_nospam at yahoo.com
Mon Jan 24 23:30:05 EST 2005
> I have a map where I have to remove all the isles present inside other
> big poligons...
> in some previous e-mails someone said to use v.extract
> list=1-9999999 .... but I wasn't able to obtain results this way...
nothing was extracted or everything was extracted?
> do you know if there are other ways to do this???
if everything was extracted (ie internal isles have centroids + category
numbers) then 'v.extract -d' should work.
if nothing was extracted then you might have to run 'v.category option=add'.
use 'd.vect cats=1-9999999' and see what plots? isles should not be
filled or have centroid marks. ?
Hamish
