[GRASSLIST:5528] Re: g.gisenv is not compiling for arm linux
Force3 Team subscription at force3-india.org
Wed Jan 26 06:05:53 EST 2005
Paul Kelly wrote:
> On Wed, 26 Jan 2005, Force3 Team wrote:
>> Hi,
>> I am trying to compiling the Grass for Arm-Linux,
>> Some modules are get compiled and working fine.
>> but I am facing difficulty in
>> /grass54/etc/clean_temp
>> /grass54/etc/run
>> g.gisenv
>> If any one have a copy of These compiled files from Arm Linux
>> Kindly send me, or suggest a link to download
>> The Error Log says ..
>> Compilation error in module: src/general/g.gisenv
> You need to post the output from the make command showing the actual
> errors before anybody can do anything about it. Also I think large parts
> of 6.0 are not really safe for cross-compiling (e.g. after compiling a
> module it is run to generate the man pages; that won't work if you're
> cross-compiling). 5.4 might be a little better but cross-compiling isn't
> well tested AFAIK.
> Paul
Do We need the Error Log, or the Output of ./configure file ?
or Both ?
Regards
Prachait
