[GRASSLIST:5531] Re: g.gisenv is not compiling for arm linux
    Force3 Team
    subscription at force3-india.org
    Wed Jan 26 07:09:57 EST 2005
Paul Kelly wrote:
> On Wed, 26 Jan 2005, Force3 Team wrote:
>>>> The Error Log says ..
>>>> Compilation error in module: src/general/g.gisenv
>>> You need to post the output from the make command showing the actual
>>> errors before anybody can do anything about it. Also I think large
>>> parts of 6.0 are not really safe for cross-compiling (e.g. after
>>> compiling a module it is run to generate the man pages; that won't
>>> work if you're cross-compiling). 5.4 might be a little better but
>>> cross-compiling isn't well tested AFAIK.
>>> Paul
>> Do We need the Error Log, or the Output of ./configure file ?
>> or Both ?
> No, neither of those. As I said, the output of make.
> make > make.log 2>&1
> should capture it if you're using bourne/bash shell.
> Paul
Hi Paul.
I have uploaded the files which are required by you
./configure  OUTPUT => configure.log
make    OUTPUT => make.log
make install OUTPUT => makeinstall.log
Reset in comm you will fine parameter passed in ./configure.
Kindly write, if you need more information.
Thanks in Advance.
Regards, and  Have a nice day.
Prachait Saxena
Force3 Team
(M) :- +91 98229 44025
(M) :- +91 93732 81318
(E) :- prachait (at) force3-india (dot) com
(E) :- subscription (at) force3-india (dot) com
(W) :- http://www.force3-india.org/
_________________________________
Our Solution at Microsoft Solution Market Place
Public Grievance Redressal System version 1.0.0
http://www.microsoft.com/asia/solutionmarketplace/solutiondetail.asp?ind=3&sid=30101&type=1&solid=1760&language=1&searchresult=true&sLanguage=1
Checkout Latest:
http://force3-india.org/downloads/Presentations/Force3-India_inCLASS-Presentation.zip
