[GRASSLIST:5532] Re: g.gisenv is not compiling for arm linux
Paul Kelly
paul-grass at stjohnspoint.co.uk
Wed Jan 26 07:17:20 EST 2005
On Wed, 26 Jan 2005, Force3 Team wrote:
> Paul Kelly wrote:
>>>> You need to post the output from the make command showing the actual
>>>> errors before anybody can do anything about it. Also I think large
>>>> parts of 6.0 are not really safe for cross-compiling (e.g. after
>>>> compiling a module it is run to generate the man pages; that won't
>>>> work if you're cross-compiling). 5.4 might be a little better but
>>>> cross-compiling isn't well tested AFAIK.
>>>> Paul
>>> Do We need the Error Log, or the Output of ./configure file ?
>>> or Both ?
>> No, neither of those. As I said, the output of make.
>> make > make.log 2>&1
>> should capture it if you're using bourne/bash shell.
>> Paul
> Hi Paul.
> I have uploaded the files which are required by you
> ./configure OUTPUT => configure.log
> make OUTPUT => make.log
That file only seems to contain the standard output of make. You need to
redirect the standard error into the logfile as well. As I said,
should do it.
