[GRASSLIST:5560] Re: v.in.e00, v.in.ogr problems
    Hamish
    hamish_nospam at yahoo.com
    Sun Jan 30 23:34:30 EST 2005
ERROR: Cannot open data source
This error comes after it tries to read dsn=
> I believe so. I was following the example for Arc/Info coverages.
this one?
 http://grass.ibiblio.org/grass60/manuals/html60_user/v.in.ogr.html
what files does 'avcimport' produce?
> I made dsn the coverage directory (rail1),
correct.
> and layer to the feature I wished to import (Arcs/lines).
layer should be the shape file name (without the extension),
e.g. rail.shp, not what is in it.
This should list available layers:
v.in.ogr -l dsn=... output=test
        (-l is a lower case "L" not a one)
what file names are in /volumes/wooster/test/rail1 ?
For shape file input should be *.shp *.shx *.dbf *.sbn *.sbx (*.prj)
You might try viewing the shape files with other software, e.g.:
JUMP   http://www.jump-project.org/project.php?PID=JUMP&SID=OVER
QGIS   http://qgis.sourceforge.net
to find out if the files are ok.
Hamish
