[GRASSLIST:5564] raster reprojection
samuel cavalcante rioapaporis at yahoo.com.br
Mon Jan 31 11:02:26 EST 2005
hi ,
what i have to do to reproject a raster that is in a different projection  to current location´s projection?
i have to quit the location an then import this raster in another location whith the desired projection?
thanks
samuel
Radim Blazek <blazek at itc.it> wrote:
For me it works.
v.mkgrid map=pok grid=3,2 position=region
v.extract input=pok output=pok2 type=area list=4
Number of boundaries: 8
Number of centroids : 1
Radim
Dylan Beaudette wrote:
> Radim,
> Thanks for the idea... but doing v.extract type=area leaves me with only the
> centroids for each grid cell...
> is there anyway to convert a set of line segments into a polygon?
> thanks!
> Dylan
> On Thursday 27 January 2005 12:14 am, Radim Blazek wrote:
>>Use v.extract type=area
>>Radim
>>>On Wednesday 26 January 2005 06:09 pm, Hamish wrote:
>>>>>I have used v.mkgrid (GRASS6-CVS) in the past to make vector grids,
>>>>>and all has been well.
>>>>>However, this morning I tried to extract a single square from the
>>>>>output from v.mkgrid, and was only able to get either a single
>>>>>centroid (almost correct), or the entire boundary (not good). Since
>>>>>the boundaries do not have CATs, there is no way for me to extract a
>>>>>single boundary...
>>>>>Any ideas?
>>>>what about
>>>> v.category type=boundary option=add
>>>>to add category numbers to the boundaries?
>>>Thanks! ... this gives the boundaries CATs... but for some reason, each
>>>grid square is made up of about 8 line segments (3 for top and bottom
>>>lines, 1 for each vertical line)...
>>>My hope is that i can make each grid "cell" into a discreet polygon, that
>>>can be used to set the region -- i.e. so that i can accurately subsample
>>>a larger map.
>>>thanks!
Yahoo! Acesso Grátis - Internet rápida e grátis. Instale o discador do Yahoo! agora.
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20050131/e5280cb9/attachment.html
