[GRASSLIST:5565] Re: raster reprojection
Ian MacMillan ian_macmillan at umail.ucsb.edu
Mon Jan 31 12:56:17 EST 2005
Samuel,
If you have imported your raster into location 1, then exit that
location.  Open up location 2 (your desired projection) and set your
region to match the incoming raster with g.region w= e= s= n=
Following this, use r.proj in location 2 to bring in your raster from
location 1.  This is different only if location 1 is an XY location
(without projection info).  If so, write back and let us know, or look
at the mail archives.
G'luck
-Ian
On Jan 31, 2005, at 8:02 AM, samuel cavalcante wrote:
> hi ,
> what i have to do to reproject a raster that is in a different
> projection  to current location´s projection?
> i have to quit the location an then import this raster in another
> location whith the desired projection?
> thanks
> samuel
> Radim Blazek <blazek at itc.it> wrote:
> For me it works.
> v.mkgrid map=pok grid=3,2 position=region
> v.extract input=pok output=pok2 type=area list=4
> Number of boundaries: 8
> Number of centroids : 1
> Radim
> Dylan Beaudette wrote:
> > Radim,
> > Thanks for the idea... but doing v.extract type=area leaves me with
> only the
>  > centroids for each grid cell...
> > is there anyway to convert a set of line segments into a polygon?
> > thanks!
> > Dylan
> > On Thursday 27 January 2005 12:14 am, Radim Blazek wrote:
> >>Use v.extract type=area
> >>Radim
> >>>On Wednesday 26 January 2005 06:09 pm, Hamish wrote:
> >>>>>I have used v.mkgrid (GRASS6-CVS) in the past to make vector
> grids,
> >>>>>and all has been well.
> >>>>>However, this morning I tried to extract a single square from the
> >>>>>output from v.mkgrid, and was only able to get either a single
> >>>>>centroid (almost correct), or the entire boundary (not good).
> Since
> >>>>>the boundaries do not have CATs, there is no way for me to
> extract a
> >>>>>single boundary...
> >>>>>Any ideas?
> >>>>what about
> >>>> v.category type=boundary option=add
> >>>>to add category numbers to the boundaries?
> >>>Thanks! ... this gives the boundaries CATs... but for some reason,
> each
> >>>grid square is made up of about 8 line segments (3 for top and
> bottom
> >>>lines, 1 for each vertical line)...
> >>>My hope is that i can make each grid "cell" into a discreet
> polygon, that
> >>>can be used to set the region -- i.e. so that i can accurately
> subsample
> >>>a larger map.
> >>>thanks!
> &gtt;
>  Yahoo! Acesso Grátis - Internet rápida e grátis. Instale o discador
> do Yahoo! agora.
Name: not available
Type: text/enriched
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20050131/73cc534f/attachment.bin
