[GRASSLIST:5571] raster reprojection lambert azimutal to lat-lon
Miguel A. Altamirano del C
mgaac at yahoo.com
Mon Jan 31 18:21:42 EST 2005
I've an ETOP30 subproduct with "lambert azimutal equal
area" projection which a get in "location 1", the file
WIND generate has the following information:
proj: 4
zone: 1
north: 4384500
south: -3999500
east: 4639500
west: -4462500
cols: 9102
rows: 8384
When a try to change of projection (to lat-lon) in
"location 2" setting my region to match the incoming
raster with g.region w=-137.8 e=-63.2 s=10 n=80 with
the following information in the WIND file:
proj: 3
zone: 1
north: 80
south: 10
east: -63.2
west: -137.8
cols: 9102
rows: 8384
e-w resol: 0.008196
n-s resol: 0.00834924
i get the following error:
r.proj in=altura_00 location=grasspru2
mapset=PERMANENT dbase=/home/miguel/GRASS/ out=kk00
Input Projection Parameters: +proj=laea +a=6378137
+rf=298.257223563 +no_defs +nadgrids=conus
Input Unit Factor: 1
Output Projection Parameters: +proj=latlong +a=6378137
Output Unit Factor: 1
ERROR: Input map is outside current region
How i can do the change in projection correctly??
The PROJ_INFO in location 1 has
datum: WGS84
nadgrids: conus
proj: laea
ellps: WGS84
a: 6370997.
es: 0.0067686580
f: 294.9786982000
zone: 1
and in the location 2 has
datum: WGS84
nadgrids: conus
proj: ll
ellps: WGS84
a: 6378206.4000000004
es: 0.0067686580
f: 294.9786982000
zone: 1
I'm working in the version 6.0 beta1.
LCA Miguel A. Altamirano del C.
"Los Mexicanos llevamos la fiesta en la garganta"
Tel. 01(232)32 45208
La belleza de la meteorología radica en saber
pronosticarla y no simplemente en estudiarla
(Miguel A. Altamirano 28-5-00)
_________________________________________________________
Do You Yahoo!?
Información de Estados Unidos y América Latina, en Yahoo! Noticias.
Visítanos en http://noticias.espanol.yahoo.com
