[GRASSLIST:7415] Re: grass_I error
M S mseibel at gmail.com
Fri Jul 1 14:19:54 EDT 2005
> please try this:
> cd grass-6.0.0/lib/imagery/
> make
> Which error do you get?
/usr/bin/ld: cannot find -lgrass_I
collect2: ld returned 1 exit status
make[1]: *** [/drive/rpms/grass-6.0.0/dist.i686-pc-linux-gnu/bin/i.zc] Error 1
make[1]: Leaving directory `/drive/rpms/grass-6.0.0/imagery/i.zc'
> And: do you use gcc4 (run gcc -v)?
Target: i386-redhat-linux
Configured with: ../configure --prefix=/usr --mandir=/usr/share/man
--infodir=/usr/share/info --enable-shared --enable-threads=posix
--enable-checking=release --with-system-zlib --enable-__cxa_atexit
--disable-libunwind-exceptions --enable-libgcj-multifile
--enable-languages=c,c++,objc,java,f95,ada --enable-java-awt=gtk
--with-java-home=/usr/lib/jvm/java-1.4.2-gcj-1.4.2.0/jre
--host=i386-redhat-linux
Thread model: posix
gcc version 4.0.0 20050519 (Red Hat 4.0.0-8)
