[GRASSLIST:7428] Re: [GRASS5] 3d point vectors in nviz
Michael Barton
michael.barton at asu.edu
Sun Jul 3 00:18:13 EDT 2005
Markus,
Does the random point generator now work on Mac's too? It didn't work on
Mac's a month back.
Michael
On 7/1/05 8:23 AM, "Markus Neteler" <neteler at itc.it> wrote:
> Yes, it works. I have right now extended v.random to optional 3D support
> to easily generate test data:
> - launch GRASS with Spearfish60
> - run
> g.region rast=elevation.dem -p
> v.random -z out=rand3d n=25 zmin=1200 zmax=2500
> v.info rand3d
> nviz elevation.dem
> # load vector points in "Vector points" menu, "NEW" button
> # then select "3D Points", draw
> Works well...
> Markus
> On Fri, Jul 01, 2005 at 10:33:24AM +0200, benducke at compuserve.de wrote:
>> Yes, I did, but the results were no different
>> rom the Display on Surface option.
>> Is the "3D Points" option known to work?
>>> ----- Originalnachricht -----
>>> Von: Markus Neteler <neteler at itc.it>
>>> Datum: Freitag, 1. Juli 2005 8:54 am
>>> Betreff: [GRASSLIST:7400] Re: 3d point vectors in nviz
>>>> On Thu, Jun 30, 2005 at 03:32:16PM +0200, benducke at compuserve.de
>>>> wrote:> Has anyone successfully managed to get a 3D points cloud
>>>>> to display correctly in nviz?
>>>>> I checked 3D region settings and the structure of the
>>>>> vector file itself. The data and settings seem fine.
>>>>> I can display the zcoords with d.vect and it looks
>>>>> ok.
>>>>> However, when I load the map into nviz, I only get
>>>>> to see the top points of the vector map (i.e. I get
>>>>> to see as much as the top-down view by d.vect),
>>>>> the remaining points do not get displayed.
>>>>> I would very much appreciate any help!
>>>> Did you activate "3D Points" in the Vector points menu?
>>>> Markus
____________________
C. Michael Barton, Professor of Anthropology
School of Human Evolution and Social Change
PO Box 872402
Arizona State University
Tempe, AZ 85287-2402
USA
Phone: 480-965-6262
Fax: 480-965-7671
www: <www.public.asu.edu/~cmbarton>
