[GRASSLIST:7411] Re: [GRASS5] 3d point vectors in nviz
    Markus Neteler
    neteler at itc.it
    Fri Jul  1 11:23:54 EDT 2005
Yes, it works. I have right now extended v.random to optional 3D support
to easily generate test data:
- launch GRASS with Spearfish60
- run
   g.region rast=elevation.dem -p
   v.random -z out=rand3d n=25 zmin=1200 zmax=2500
   v.info rand3d
   nviz elevation.dem
   # load vector points in "Vector points" menu, "NEW" button
   # then select "3D Points", draw
Works well...
Markus
On Fri, Jul 01, 2005 at 10:33:24AM +0200, benducke at compuserve.de wrote:
> Yes, I did, but the results were no different
> rom the Display on Surface option.
> Is the "3D Points" option known to work?
> > ----- Originalnachricht -----
> > Von: Markus Neteler <neteler at itc.it>
> > Datum: Freitag, 1. Juli 2005 8:54 am
> > Betreff: [GRASSLIST:7400] Re: 3d point vectors in nviz
> > > On Thu, Jun 30, 2005 at 03:32:16PM +0200, benducke at compuserve.de
> > > wrote:> Has anyone successfully managed to get a 3D points cloud
> > > > to display correctly in nviz?
> > > > I checked 3D region settings and the structure of the
> > > > vector file itself. The data and settings seem fine.
> > > > I can display the zcoords with d.vect and it looks
> > > > ok.
> > > > However, when I load the map into nviz, I only get
> > > > to see the top points of the vector map (i.e. I get
> > > > to see as much as the top-down view by d.vect),
> > > > the remaining points do not get displayed.
> > > > I would very much appreciate any help!
> > > Did you activate "3D Points" in the Vector points menu?
> > > Markus
Markus Neteler     <neteler itc it>       http://mpa.itc.it
ITC-irst -  Centro per la Ricerca Scientifica e Tecnologica
MPBA - Predictive Models for Biol. & Environ. Data Analysis
Via Sommarive, 18        -       38050 Povo (Trento), Italy
