[GRASSLIST:7405] 3d point vectors in nviz
benducke at compuserve.de
Fri Jul 1 04:33:24 EDT 2005
Yes, I did, but the results were no different
rom the Display on Surface option.
Is the "3D Points" option known to work?
> ----- Originalnachricht -----
> Von: Markus Neteler <neteler at itc.it>
> Datum: Freitag, 1. Juli 2005 8:54 am
> Betreff: [GRASSLIST:7400] Re: 3d point vectors in nviz
> > On Thu, Jun 30, 2005 at 03:32:16PM +0200, benducke at compuserve.de
> > wrote:> Has anyone successfully managed to get a 3D points cloud
> > > to display correctly in nviz?
> > > I checked 3D region settings and the structure of the
> > > vector file itself. The data and settings seem fine.
> > > I can display the zcoords with d.vect and it looks
> > > ok.
> > > However, when I load the map into nviz, I only get
> > > to see the top points of the vector map (i.e. I get
> > > to see as much as the top-down view by d.vect),
> > > the remaining points do not get displayed.
> > > I would very much appreciate any help!
> > Did you activate "3D Points" in the Vector points menu?
> > Markus
