[GRASSLIST:7429] Re: silly question?
Hamish
hamish_nospam at yahoo.com
Sun Jul 3 04:38:08 EDT 2005
> I've been an <GASP> E$RI arc/info workstation user for 10+ years, and
> i'm finally (successfully) jumping ship. from what i read, i see,
> GRASS can do everything workstation can, not to mention its
> plug-ability with Quantum GIS and other open source software.
> Does anyone know if there has ever been a document created that is
> somewhat of a HOWTO in a GRASS approach from a workstation mindset?
> In other words, is there some document that illustrates tasks
> performed in workstation with corrisponding commands document of how
> to do the same procedures in GRASS?
I remember someone talking about putting such a document together maybe 6
months ago; you'd have to search the mailing list archive for it.
I seem to recall the discussion went something like "please document
your progress and post your findings to the Wiki so that others might
benefit from your journey." I don't know if that ever happened, but you
might take up the same task. It is very hard for those without a ESRI
background to know what the preconceived ways of doing things are. ie it
needs to be done by someone in your shoes.
http://grass.gdf-hannover.de/twiki/bin/view/GRASS/WebHome
One thing to realize is that GRASS was historically a raster based GIS
while Arc was a vector based GIS. So GRASS's imagery and grid operations
are very mature. Only with the latest release (6.0) has GRASS had a
very strong vector engine too, so documentation and fine tuning for
vectors is still just arriving weekly.
> The biggest stumbling block for me was, believe it or not, setting up
> the GISDBASE, LOCATION & MAPSET. once i got that understood stuff
> started falling into place for me.
The hardest part of GRASS used to be installing it. Now this has moved
on to being the opening screen. Progress!
Some recommended reading:
"GRASS Quickstart" by M. Neteler (in the GRASS help pages)
http://grass.ibiblio.org/grass61/manuals/html61_user/helptext.html
"Visual Tutorial for GRASS 6" by L. Moretti (for non-UNIX people, GUI)
http://wwwamb.bologna.enea.it/forgrass/documents/Grass-6-Visual-Tutorial.pdf
"Open Source GIS: A GRASS GIS Approach. 2nd ed." by M. Neteler and
H. Mitasova (Book; GRASS 5 but non-vector/sites chapters still valid)
http://mpa.itc.it/grassbook2
"An introduction to the practical use of the Free Geographical
Information System GRASS 6.0" by GDF Hannover
http://www.gdf-hannover.de/lit_html/grass60_v1.1_en/
More GRASS documentation and tutorials:
http://grass.ibiblio.org/gdp/index.php
> Also, is there a more thorough explanation of what v.digit can do other
> than http://grass.itc.it/gdp/html_grass5/html/v.digit.html ? v.digit
> seems quite powerful, and i compare it to ArcEdit (by nature of being
> schooled in the "workstation" approach to GIS). I recognize i can and
> should RTFM, but being so ingrained in that OTHER software's approach,
> it often messes with my thought process, as i often try to relate
> commands from one software's approach to another, which is probably
> not the best thing to do.
It is poorly documented, perhaps the GDF Hannover guide covers it?
It is very good for fixing broken nodes etc. Still many wishes & fine
tuning need to be done before it will be a really strong program, but
the base is there. As others have mentioned, QGIS+GRASS does well as a
substitute.
> some examples are:
> digitizing/editing topologic vector data
v.digit or QGIS+GRASS
> rectifying images
i.points, i.target, i.rectify. Or use gdalwarp from gdal.org
> working with GIS vector database attributes (i.e. table manipulation
> and changing attributes)
see the various GRASS 6 tutorials, e.g. this one:
http://grass.gdf-hannover.de/twiki/bin/view/GRASS/GrassSixTutorial
(I'm pretty sure there was more to that which hasn't been put in the Wiki
yet??)
> overlaying vector data with attribute information
- 'd.vect display=attr'
- v.label + d.paint.labels (improvements in active development)
> cut/fill operations
- v.overlay, v.select, v.extract, et al.
- v.to.rast
- MASK raster maps and r.mapcalc
> cartographic operations for hardcopy maps
- ps.map can make really nice output (once you learn how)
- export to GMT for journal quality figures
http://gmt.soest.hawaii.edu/
http://169.237.35.250/~dylan/grass_user_group/#GMT_and_GRASS-overview
> Its probably a silly question. But often times i find my self saying
> "i know how to do this in workstation, I know GRASS can do this, but
> how do i proceed?"
GRASS is very powerful at the low level, so with any task the
functionality usually exists in GRASS, it's just a matter of figuring
out how/where to look. Side effect of this is that one of GRASS's real
strong points is its ability to run scripted.
> anyone else out there transition from that OTHER software company to
> GRASS? and what was the best way you handled the migration? I cant
> totally throw out everything i know about workstation, but cause the
> concepts are the same. its the specific commands and methodology that
> often have my head spinning...
Just takes time....
> cheers to all users and developers! GRASS is an amazing piece of GIS
> software!
I agree!
be sure to try NVIZ too.
Hamish
