[GRASSLIST:7448] Re: r.terraflow failured
orkun temiz at deprem.gov.tr
Mon Jul 4 17:27:15 EDT 2005
David Finlayson wrote:
>r.terraflow makes large temp files during the operation. Check the
>STREAM_DIR (defaults to /var/tmp) you assigned I would bet that one of
>those temp files exceeded 2 Gb. That seems to be the filesize limit on
>my distribution of linux.
>Davids
>On 7/4/05, orkun <temiz at deprem.gov.tr> wrote:
>>hello
>>At first time I tried to run r.terraflow in a small test area. I
>>failured. It gave this error:
>>r.terraflow elev=el_5  filled=el5-filled  dir=el5-mfdir
>>swatershed=el5-watershed accumulation=el5-accu tci=el5-tci
>>assigning directions on plateaus
>>File size limit exceeded
>>Could you tell me why ?
>>regards
>>Ahmet Temiz
>>______________________________________
>>XamimeLT - installed on mailserver for domain @deprem.gov.tr
>>Queries to: postmaster at deprem.gov.tr
>>The views and opinions expressed in this e-mail message are the sender's own
>>and do not necessarily represent the views and the opinions of Earthquake Research Dept.
>>of General Directorate of Disaster Affairs.
>>Bu e-postadaki fikir ve gorusler gonderenin sahsina ait olup, yasal olarak T.C.
>>B.I.B. Afet Isleri Gn.Mud. Deprem Arastirma Dairesi'ni baglayici nitelikte degildir.
thank you
You are right.
that file made my disk full.
Although I used a small region for testing purposes. It produced
giantic files.
I do not know what will happen if I use whole region ?
what do you suggest ?
regards
