[GRASSLIST:7507] Re: attribute for boundary and arcinfo-coverage
Hamish
hamish_nospam at yahoo.com
Sun Jul 10 00:54:51 EDT 2005
> is it possible in grass to define the boundary of the polygones
> between the different types of biotops and to give attributes for the
> boundaries of the polygones?
> for example:
> -the boundary between biotop typ 1 and biotop typ 1 should get the
> attribute A -the boundary between biotop typ 1 and biotop typ 2 should
> get the attribute B
Yes,
v.to.db option=sides
> is it possible to export grass-vector-layers to arcinfo-coverages and
> if yes with which precision (single/double)?
v.out.ogr's default output format is ESRI_Shapefile.
As for exporting .e00 files, try the tools you can find here:
http://avce00.maptools.org
http://www.remotesensing.org/gdal/ogr/
(follow steps of the v.in.e00 script in reverse?)
Hamish
