[GRASSLIST:7511] Re: attribute for boundary and arcinfo-coverage
Tom Russo russo at bogodyn.org
Sun Jul 10 11:04:22 EDT 2005
On Sun, Jul 10, 2005 at 04:54:51PM +1200, we recorded a bogon-computron collision of the <hamish_nospam at yahoo.com> flavor, containing:
> > is it possible to export grass-vector-layers to arcinfo-coverages and
> > if  yes with which precision (single/double)?
> v.out.ogr's default output format is ESRI_Shapefile.
> As for exporting .e00 files, try the tools you can find here:
> http://avce00.maptools.org
> http://www.remotesensing.org/gdal/ogr/
> (follow steps of the v.in.e00 script in reverse?)
OGR can't write arc/info binary coverages, it can only read them.  So the
reverse process of v.in.e00 won't work (it converts e00 into avcbin, then uses
v.in.ogr to read that).  The tool sets on those two websites don't provide
what would be needed to get Grass to export to an arc/info coverage.
Tom Russo    KM5VY     SAR502  DM64ux         http://www.swcp.com/~russo/
Tijeras, NM  QRPL#1592 K2#398  SOC#236 AHTB#1
 "The only thing you can do easily is be wrong, and that's hardly
  worth the effort." -- Norton Juster
