[GRASSLIST:7512] Re: attribute for boundary and arcinfo-coverage
    Helmut Kudrnovsky
    hellik at web.de
    Sun Jul 10 11:48:16 EDT 2005
russo at bogodyn.org schrieb am 10.07.05 17:05:17:
On Sun, Jul 10, 2005 at 04:54:51PM +1200, we recorded a bogon-computron collision of the <hamish_nospam at yahoo.com> flavor, containing:
> > is it possible to export grass-vector-layers to arcinfo-coverages and
> > if  yes with which precision (single/double)?
>> v.out.ogr's default output format is ESRI_Shapefile.
>> As for exporting .e00 files, try the tools you can find here:
> >http://avce00.maptools.org
>> http://www.remotesensing.org/gdal/ogr/
>> (follow steps of the v.in.e00 script in reverse?)
>OGR can't write arc/info binary coverages, it can only read them.  So the
>reverse process of v.in.e00 won't work (it converts e00 into avcbin, then uses
>v.in.ogr to read that).  The tool sets on those two websites don't provide
>what would be needed to get Grass to export to an arc/info coverage.
surfing through the online-manual of grass 5.3.x (http://grass.itc.it/gdp/html_grass5/index.html), there is v.out.arc -("Exports GRASS vector files to ARC/INFO's "ungenerate" file format") and v.out.e00 ("Write an Arc-Info line/polygon coverage in e00 format") described, but in the online-manual of grass 6.0 there are none of these two modules.  in the module porting status from 5.3 to 6.0 both (v.out.arc, v.out.e00) are in the list.  what is the actual status?
greetings
helli
Tom Russo    KM5VY     SAR502  DM64ux         http://www.swcp.com/~russo/
Tijeras, NM  QRPL#1592 K2#398  SOC#236 AHTB#1
 "The only thing you can do easily is be wrong, and that's hardly
  worth the effort." -- Norton Juster
_________________________________________________________________________
Mit der Gruppen-SMS von WEB.DE FreeMail können Sie eine SMS an alle
Freunde gleichzeitig schicken: http://freemail.web.de/features/?mc=021179
