[GRASSLIST:7531] vectorisation - vertex limit?
Martin Rutzinger
Martin.Rutzinger at uibk.ac.at
Wed Jul 13 08:23:09 EDT 2005
Hi all!
I try to vectorize a thinned (r.thin) raster map with r.to.vect. After that I
build the topology and create polygons with v.build. This works fine for small
regions, but if I choose a larger one the vectorisation is not finished
properly. It seems like r.to.vect starts at the top of the region and finishes
if a certain value of vetices was made. I can visualise the result, but I can't
built the topology with this vector (ERROR: Cannot open old vector
mwin_vector1 at schlesi on level 2).
I zoomed into the extent of the unfinished vector and tryed again:
Building topology ...
42238 primitives registered
Building areas: 100%
0 areas built
0 isles built
Attaching islands:
Attaching centroids: 100%
Topology was built.
Number of nodes : 37573
Number of primitives: 42238
Number of points : 0
Number of lines : 42238
Number of boundaries: 0
Number of centroids : 0
Number of areas : 0
Number of isles : 0
Is there a limit of primitives around 42238 in the vector format?
Is it possible to handle larger vectors?
thank you
Martin
________________________________________________________________________________
hang loose!
