[GRASSLIST:7540] Re: d.rast.leg bug?
Wed Jul 13 18:34:32 EDT 2005
> > it's seems that the subdivision of the monitor in two parts when
> > running d.rast.leg is a permanent feature. Every subsequent map
> > display is performed (randomly) in one of the two monitor parts.
> > d.erase doesn't cancel the entire monitor.
> Just a guess:
> d.frame -e
> Does that work?
It should. Also Markus just added 'd.erase -f' to remove all frames as
well.
> I always used to use that command for erasing monitors before I
> discovered d.erase. In fact as far as I understand it d.erase is not
> even necessary except to save typing?
Well d.rast without -o will clear the display command list (view with
d.save) anyway, saving the step.
Hamish
