[GRASSLIST:7544] Re: d.rast.leg bug?
Markus Neteler neteler at itc.it
Thu Jul 14 04:58:32 EDT 2005
On Wed, Jul 13, 2005 at 05:33:45PM +0100, Paul Kelly wrote:
> Aldo Clerici wrote:
> >Dear GRASSusers,
> >it's seems that the subdivision of the monitor in two parts when running
> >d.rast.leg is a permanent feature. Every subsequent map display is
> >performed
> >(randomly) in one of the two monitor parts.
Dear Aldo,
it's not randomly, but done on the left side (the last activated
frame). But, if the user resizes the screen, it switches to the
right side which apparently becomes the last frame after resize-redraw.
> d.erase doesn't cancel the
> >entire monitor.
In 6.1 there is now
 d.erase -f
to erase all frames. Without -f the active frame will be erased.
> Just a guess:
> d.frame -e
> Does that work?
Yes, that's the (classical) alternative.
Markus
