[GRASSLIST:7569] how does v.to.rast work...
"Zaboj Hrazsky, DAPHNE ČR" zaboj.hrazsky at daphne.cz
Sat Jul 16 12:02:28 EDT 2005
Hi
One can say daily task...
I need to get rasters with cell 100m from large vector file with
variable area of polygons: from 20 m2 to hectars. I must not lost any
occurence of small polygons (which often are generalized out in such
cases). The best result for me is raster with values of "my vector" area
in each cell, but also the only presence/absence in 100m grid can be
used for further analysis.
There are more ways:
A) use v.mkgrid and overlay these vectors works well, but in case of 1
400 000 cells in grid I've found some limits :-(.
    v.mkgrid  map=grid100 grid=2926,4728 position=region
    Creating vector grid ...
    Writing out vector rows ...
    Writing out vector columns ...
    Creating centroids ...
    dbmi: Protocol error (invalid table/column name or unsupported
column type)
    ERROR: Cannot insert row: insert into gridall values ( 822223, 174,
4279 )
B) use v.to.rast
B1) plain v.to.rast - see file v.to.rast_centroids.png - leave many
pieces outside the result raster. What is the algorithm, how does GRASS
know which cell falls in resultant raster?
B2) to add category to vector boundaries and run  v.to.rast  ...  see
boundary.png ...  the  result raster eats to much ... empty cells were
involved, Question is why?
B3) the most complicated, but with best results now: v.to.rast in small
(5m or less) cell size -> r.to.vect feature=point -> v.to.rast in 100m
cell size works with points well. I tried to use v.to.points and patch
these "linepoints" and "rasterpoints" before second v.to.rast, but with
no better result.
B4) convert raster with small size cell direct to 100m raster, but I
didn't find any functionality which can simulate the Agregate() function
known from ESRI  GIS products, which sumarize values from finer raster
into cell of coarser one. Any mc
There is no C for me (not programator :), but maybe anybody can navigate
me a bit ...
Thanks for your time
    Záboj Hrázský
   ___________________________________________
    DAPHNE ČR - Institut aplikované ekologie
    Husova 45, 370 05 České Budějovice
    http://www.daphne.cz
    Tel: +420 776053573
    ICQ: 332817882
Type: image/png
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20050716/edf14be7/v.to.rast_centroids.png
Type: image/png
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20050716/edf14be7/boundary.png
