[GRASSLIST:7576] Re: Synergy between Grass/Python/GMT
David Finlayson david.p.finlayson at gmail.com
Sun Jul 17 17:17:10 EDT 2005
I have posted my GRASS -> GMT script on my web site (r.out.gmt.py):
http://students.washington.edu/dfinlays/scripts/
If anyone finds this useful, please send me suggestions. I will keep
working on it until it isn't such a hack.
Currently, it converts a raster, its colormap and optionally an
intensity raster (such as shaded relief) to GMT format. It then builds
a skeleton GMT plotting file that includes the raster (optionally
shaded with the intensity grid), a graticule and map decorations with
all of the tedious scale calculations already performed.
You need to edit the results to get it to look right, but the time
savings (for me) is probably close to an hour a plot over doing the
same steps manually.
David
On 7/16/05, Dylan Beaudette <dylan at iici.no-ip.org> wrote:
> David,
> I am extremely interested in any possible ways to streamline the
> GRASS-GMT workflow.
> I have started documenting a BASH shell version of the process, but a
> python interface might be able to provide a tremendous amount of
> flexibility compared to BASH.
> The website where this is documented is currently down (power outage
> while I was out in the field...), but I will try and have it back up in
> a couple hours. Please let me know about any future plans with this--
> Cheers,
> Dylan Beaudette
> Soils and Biogeochemistry Graduate Group
> University of California at Davis
> 530.754.7341
> On Jul 15, 2005, at 10:39 PM, David Finlayson wrote:
> > I'd be happy to share it, but frankly it's pretty crude. I'd be
> > embarrassed to foist this off as a good example of either Grass or
> > Python (though maybe it is a good example of how flexible this
> > combination is, even for light-weight programmers). The class simply
> > wraps an interface around a few standard GRASS commands and captures
> > the results (r.region for example). My dream is to write a real Python
> > interface to the Grass programming interface, but that project is on
> > hold until I finish my PhD.
> > Is there a good place on the wiki for sharing scripts? When I get this
> > GMT thing polished up I think it will be quite useful for folks who
> > use GMT.
> > David
> > On 7/15/05, Stephan Holl <holl at gdf-hannover.de> wrote:
> >> Hello David,
> >> On Fri, 15 Jul 2005 16:27:18 -0700 David Finlayson
> >> <david.p.finlayson at gmail.com> wrote:
> >>> I've been working on a script to convert GRASS rasters directly into
> >>> GMT plots in a single command. So far it converts the raster to GMT
> >>> format, copies over the colormap and builds a simple graticule and
> >>> scale bar. Works well.
> >>> In the process of building this script, however, I discovered there
> >>> is
> >>> some great synergy possible between IPython (the interactive python
> >>> shell) and GRASS. Here is how it works:
> >>> 1) Launch ipython from within your grass shell
> >>> 2) import a simple class designed to work with rasters
> >>> 3) BINGO! you've got full control of command line grass + full
> >>> interactive Python abilities.
> >>> The class I wrote for grass rasters contains a bunch of instance
> >>> variables that hold basic info about the raster (resolution, bounding
> >>> box, etc.) and some methods to ease interaction with Python, like a
> >>> get_value(X, Y) method.
> >> Would you like to share the python class which you wrote for
> >> raster-maps?
> >> It would be nice having the class in CVS to make it possible for
> >> others
> >> too?
> >>  Thanks for your comment
> >>         Stephan
> >>        ::ACHTUNG:: Neue Adresse und Telefonnummer ::ACHTUNG::
> >> GDF Hannover - Solutions for spatial data analysis and remote sensing
> >> Hannover Office      -     Mengendamm 16d      -     D-30177 Hannover
> >> Internet: www.gdf-hannover.de      -      Email: holl at gdf-hannover.de
> >> Phone : ++49-(0)511.39088507       -        Fax: ++49-(0)511.39088508
> > David Finlayson
> > Marine Geology & Geophysics
> > School of Oceanography
> > Box 357940
> > University of Washington
> > Seattle, WA  98195-7940
> > USA
> > Office: Marine Sciences Building, Room 112
> > Phone: (206) 616-9407
> > Web: http://students.washington.edu/dfinlays
David Finlayson
Box 357940
USA
