[GRASSLIST:7586] Re: Compilation errors of Fedors Core 4
Miha Staut
mihastaut at yahoo.co.uk
Mon Jul 18 04:08:44 EDT 2005
Thanks Glynn,
I tried to do as you said. So
make CFLAGS_WARNING= 2> std.error.txt
It seemed to me that no less warnings appeared (130 KB of text in all). I am
therefore sending the std. error output as an attachment. I am reminding again
that predominantly imagery commands had problems (according to error.log) while
for the others v.surf.rst, r.grow2, r.in.gdal (normal), r.param.scale,
r.resamp.rst, r.surf.gauss, r.surf.random, s.in.ascii, s.surf.rst,
r.hydro.CASC2D, r.surf.fractal, r.terraflow (normal).
I found it interesting that the CVS snapshot of GRASS 6.1 compiled appearently
without problems while the version from tarball of the CVS source tree did not.
The same was not true for GRASS 5.x.
Miha Staut
--- Glynn Clements <glynn at gclements.plus.com> wrote:
> Miha Staut wrote:
> > I recently upgraded to Fedora Core 4. When tried to restore my system I was
> > surprised to find out that GRASS 5 and 6 do not compile without significant
> > errors as they did before. Below is the error.log of grass 5.5 compilation,
> > while GRASS 6.1 had so much warnings that I did not include them. It is
> evident
> > that something is cardinally wrong. Could anybody help me to clear this
> > problem.
> We would need to see some of the actual error messages.
> For 6.1, you can disable the excessive warnings by clearing
> CFLAGS_WARNING when running make, i.e.:
___________________________________________________________
Yahoo! Messenger - NEW crystal clear PC to PC calling worldwide with voicemail http://uk.messenger.yahoo.com
