[GRASSLIST:7593] Re: v.in.ascii
Ian MacMillan
ian_macmillan at umail.ucsb.edu
Mon Jul 18 09:36:54 EDT 2005
Dave, I was able to import the data as decimal degree format. I just
converted all my data in excel, then imported from there. What errors
did you get?
-ian
On Jul 16, 2005, at 5:28 AM, David Kindem wrote:
> Ian and list,
> I don't believe I ever did get a response to the original note. I've
> also tried importing in decimal degree format, again without any luck.
> Dave
> On Jul 15, 2005, at 4:18 PM, Ian MacMillan wrote:
>> Dave (or anyone else),
>> I was wondering if you ever found out how to import lat-long data
>> into grass? I would like to do the same thing.
>> -Ian
>> Hello,
>> I'm attempting to us v.in.ascii to import sites. Things work fine
>> when I use Eastings/Northings. However, I would like to import
>> points in latitude/longiture. When I attempt to import positions
>> such as:
>> 85:46:05.14203W | 43:00:07.320715N
>> I receive the error message:
>> ERROR: x column is not of number type
>> Is there a way to have the program recognize lat./long as legitimate
>> entries?
>> Thanks,
>> Dave Kindem
>> Grand Haven, MI
Name: not available
Type: text/enriched
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20050718/f0b2c3a1/attachment.bin
