[GRASSLIST:7596] Re: v.in.ascii
    Dave Kindem
    dkindem at chartermi.net
    Mon Jul 18 13:06:45 EDT 2005
I see what my problem was.  When I tried to import in decimal degree,
I formatted the entry as 86.0000W.  When I use the +/- notation,
everything is fine.
Thanks to all for the information.
Dave
On Jul 18, 2005, at 9:36 AM, Ian MacMillan wrote:
> Dave, I was able to import the data as decimal degree format.  I
> just converted all my data in excel, then imported from there.
> What errors did you get?
> -ian
> On Jul 16, 2005, at 5:28 AM, David Kindem wrote:
>> Ian and list,
>> I don't believe I ever did get a response to the original note.
>> I've also tried importing in decimal degree format, again without
>> any luck.
>> Dave
>> On Jul 15, 2005, at 4:18 PM, Ian MacMillan wrote:
>>> Dave (or anyone else),
>>> I was wondering if you ever found out how to import lat-long data
>>> into grass? I would like to do the same thing.
>>> -Ian
>>> Hello,
>>> I'm attempting to us v.in.ascii to import sites. Things work fine
>>> when I use Eastings/Northings. However, I would like to import
>>> points in latitude/longiture. When I attempt to import positions
>>> such as:
>>> 85:46:05.14203W | 43:00:07.320715N
>>> I receive the error message:
>>> ERROR: x column is not of number type
>>> Is there a way to have the program recognize lat./long as legitimate
>>> entries?
>>> Thanks,
>>> Dave Kindem
>>> Grand Haven, MI
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20050718/eaaa4996/attachment.html
