[GRASSLIST:7635] Re: netCDF import not working
    Jason Horn
    jhorn at bu.edu
    Wed Jul 20 07:56:14 EDT 2005
Well, it would appear that the GDAL that comes with Lorenzo Moretti's
OSX GRASS is NOT compiled with support for the netCDF format.  gdal-
config --formats does not list it.  So I guess the obvious question
is: can someone give me a hint as to how to compile GDAL with netCDF
support.  Do I have to re-compile all of GRASS, or can I just compile
the GDAL library?
Thanks,
- Jason
On Jul 20, 2005, at 4:15 AM, Markus Neteler wrote:
> Hi,
> is your GDAL version *compiled* with netCDF support?
> gdal-config --formats
> will tell you. If so, then there is still the problem that the
> netCDF driver in GDAL is limited (see its documentation):
>  http://www.gdal.org/frmt_various.html#netCDF
> In any case it is more a question for the GDAL list.
> Markus
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20050720/f90dd770/attachment.html
