[GRASSLIST:7669] Re: netCDF import not working
Glynn Clements
glynn at gclements.plus.com
Fri Jul 22 01:05:35 EDT 2005
Jason Horn wrote:
> Well, it would appear that the GDAL that comes with Lorenzo Moretti's
> OSX GRASS is NOT compiled with support for the netCDF format. gdal-
> config --formats does not list it. So I guess the obvious question
> is: can someone give me a hint as to how to compile GDAL with netCDF
> support.
In general, GDAL will enable everything which it can autodetect. If
you have installed netCDF, and GDAL doesn't detect it, you need to
check the config.log file to determine why not.
> Do I have to re-compile all of GRASS, or can I just compile
> the GDAL library?
You should be able to just re-compile the GDAL library.
