[GRASSLIST:7646] Re: GRASS data to ArcView
    Tyler Mitchell
    tjm at timberline.ca
    Wed Jul 20 14:36:48 EDT 2005
What about r.out.gdal?  It will give you several options, many of which
are supported by ArcView.  I haven't used this module, but have used
GDAL extensively.  You may even be able to just use gdal_translate (part
of http://fwtools.maptools.org) to convert GRASS raster straight to TIFF
with less headache.
Tyler
Ian MacMillan wrote:
> Martin, have you tried r.out.bin?  Also, when using r.out.ascii, did you
> specify the number of significant digits with dp=?  I might be wrong,
> but I don't think tiff supports decimal values.  I am not sure about the
> r.out.arc, i haven't really used it before.
> -Ian
> On Jul 20, 2005, at 8:10 AM, Martin Wegmann wrote:
>> Hello,
>> I just encountered the problem that my colleagues can't import data
>> exported
>> from GRASS appropriately into ArcView.
>> I tried to convince them to use GRASS but without success so far ,-)
>> the raster to export specs are:
>> Type of Map:  raster              Number of Categories: 255
>> Data Type:    DCELL
>> Rows:         2230
>> Columns:      3434
>> Total Cells:  7657820
>> Range of data:    min =  0.000000 max = 35.653061
>> r.out.tiff input=test output=test -t //results in 3 bands in ArcView
>> not in
>> one; from ERDAS I know that I can specify if 1 or 3 (RGB) bands shall be
>> exported
>> r.out.arc input=test output=- > test.grd //results in no image at all
>> r.out.ascii does not import as well.
>> I recognised missing endings of the exported files. Do I have to add
>> certain
>> file specifications?
>> Any experience with GRASS -> ArcView communication?
>> regards, Martin
>> Martin Wegmann
>> DLR - German Aerospace Center
>> German Remote Sensing Data Center
>> Dept.of Geography
>> Remote Sensing and Biodiversity Unit
>> University of Wuerzburg
>> Am Hubland
>> 97074 Würzburg
>> phone: +49-(0)931 - 888 4797
>> fax:   +49-(0)931 - 888 4961
>> http://www.biota-africa.org
>> http://www.biogis.de
